factory 17' wheels with factory spacer???
I bought a 98 that has newer fact. AL. 17's on it..... took fronts off to change out track bar and on 1 side it had a what looks to be factory spacer/ ring. Was wondering if its supposed to be there and if it needs 2 .Because rims are a real pita to get off/ tight on center hole. I do not see any clearance problem with brakes but the newer trucks have bigger front brakes then my 98 I sure??? thanks, Nate
This was the fix for the Drift problem that the trucks had ...using wheel spacers in the front was Dodges fix for this problem...a fix that did work if you picked the right size.(work at a dodge dealer for 22yrs until back gave out)
royta
08-21-2008 07:06 AM
royta
08-19-2008 10:21 PM
