Extremely Roughg Idle, Smoke, and burnt oil!
Alright well, It has been taking my truck a long time to warm up and stop the warmup smoke. Well now I have an extremely rough Idle like it is running on three or 4 cyl. Also, I am getting some sort of fluid boiling out between my exhaust manifold and turbo flange.
I don't have a mix of coolant and oil. I do not have excessive amounts of fluid in my oil pan. The truck still runs like it is angry and strong.
I am pretty sure I have a bad injector or two, but would a bad turbo also be something that would cause these symptoms? I just need a place to start on repair.
Pulling the injectors is obviously step one, but how do I go about testing my turbo?
What else could cause these types of symptoms?
Thanks For all your help,
Jason
Jason
It seems like I would have better luck getting help with some crazy forbidden title here. . . What good is the help section if no one is willing to help?
1st Generation Admin
1 Post
i would say pull the outlet hose to the intercooler and check the turbo for any play or any oil and worse case take it off from the exhaust side and check it their for any oil leaks could be a sealm or something leaking
Oh Boy,
So I replaced injectors today. I still have the same problem. Rough idle and blue smoke below 1500rpm. Then it clears up and my truck runs fine. I am at a loss here and am really confused.
Thoughts that have run through my mind are:
Valve adjustment?
Valve Springs?
Burnt piston?
I just blew a lot of money on the injectors to find out that was not the problem. Kind of kicking myself for that one. The reason I did that was because it seemed liek my oil levels were rising. Now I am just lost! Would a failing CP3 pump cause this? What has me confused is the fact it clears up with RPM and still runs strong as could be. My truck was in a wreck about 300 miles before this happened, could chaffed wiring cause this? If so what sensors or wiring would I be looking at? ECM possible cause?
I am removing my VA C3.1 tomorrow and returning the PMT back to stock.
Any help at this point would be beyond appreciated. I cannot afford to just throw ideas at it after the injector thing...
Valve adjustment?
Valve Springs?
Burnt piston?
Cummins Guru
Do you have access to a scan tool? Can you do injection kill test? Any codes? What tests have you done? example Test for high injector return flow. Did you replace HPC tubes with new injectors did you follow tightening procedure for replacing new injectors? Base engine check, Valve lash compression test, cylinder leak down. Did you do compression test when injectors were out? Remove oil cap do you notice excessive pressure coming out?
do you tow heavy??? It sounds like you could have a cracked eghaust manifold...I have gone thru 2 on my 04.5 and eveytime It sounds like the engine is missing and running rough but it ends up being the manifold....i was thinking the turbo seal could also be bad but you would not be seeing boiling liquid (oil) at the turbo/manifold flange...basically i have no idea...pull the turbo and tell us what you find.
Also, Thanks For all the ideas guys, basically I think if all the electrical/computer stuff comes back ok then I will be pulling the head and checking things out...
