Excessive Blow By , Rough idle , White Smoke ??
Old 11-06-2007 | 02:37 PM
05CTD600's Avatar
Are these 3 related somehow ? Rough idle and white smoke on start up and lots of blow by coming out of the tube . enough that at a traffic light it looks like my truck is on fire !! Wierd thing is that it doesn't always do this . Sometimes the truck runs normal .Any ideas on whats causing this and how to fix it ??
Old 11-06-2007 | 02:50 PM
Hounddog's Avatar
Crankcase full of diesel or a burnt piston.Just a guess.
Old 11-06-2007 | 05:35 PM
Rpainter's Avatar
I say bad injector if the crackcase is overfull and you are still driving it start saving for a new motor
Old 11-06-2007 | 10:35 PM
DevilzTower's Avatar
well I'll throw this out there
With the 'dog and 'painter both coming to the same conclusion they are probably onto something ...
But I saw this while I was looking through TSBs on another problem and thought I would pass it along.
http://dodgeram.info/tsb/2005/18-041-05.htm
TSB 18-041-05
Date: December 20, 2005
Models: 2006 DH/D1 Ram Truck Heavy Duty
NOTE: This bulletin applies to Ram trucks equipped with the 5.9L Cummins 24-valve
diesel engine (sales code ETH) built on or after June 9, 2005 through and
including November 8, 2005 (MDH 0609XX and 1108XX).
Overview:
This bulletin involves programming the PCM (Cummins) with new software.
Symptom/Condition:
The vehicle operator may experience one or more of the following after the Repair Procedure is
performed:
* Reduced white smoke and improved engine performance after a cold start at ambient
temperatures below 15.5° C (60° F).
* Improved Oil Pressure Gauge Operation.
Diagnosis:
Operate the power door locks. Iif the rear door lock(s) is lnoperatve, perform the Repair Procedure.
with the build dates they are quoting on this it looks like it's just at the very tail end of the '05 run and into the beginning of the '06 run.
Just throwing it out there hoping it's the always present "Do you have the latest ECM flash" solution.
Old 11-07-2007 | 06:50 AM
paroxysym's Avatar
its only an 05, should be under warranty
Old 11-07-2007 | 02:58 PM
05CTD600's Avatar
Got 107k on the odometer , no more warranty for me
Old 11-07-2007 | 06:38 PM
Kman9090's Avatar
Stop driving it and have it checked out immadetly, sounds like your gonna be needing some motor work.
Old 11-09-2007 | 02:35 PM
05CTD600's Avatar
All 6 injectors are shot and so is the turbo . Thinks i'm gonna puke now
Old 11-09-2007 | 04:40 PM
Rpainter's Avatar
best time to upgrade is when the stocker dont work anymore
Stroked-Z
10-04-2008 11:28 AM
Toby
04-18-2005 08:20 AM
Strjock81
10-18-2004 06:36 PM
big red psd cc
14
09-01-2004 01:39 PM
big b
01-11-2004 12:15 PM
Quick Reply: Excessive Blow By , Rough idle , White Smoke ??
