Engine Temps
Engine Temps
It was cold here in Illinois this past weekend, and when I was out and about the engine temp never got any higher than ~150 degrees. So I went and ordered a cold weather cover for the radiator from DC. From what I understand this will have adjustable flaps for temp control, so at what point do you leave them all closed versus opening one up here and there?
I had left the trcuk running a bit after I had stopp ed after driving for about 40 minutes, and at idle the engine temp dropped another 20 degrees. Man these things are cold blooded! A guy at works D-Max sits at about 220 degrees when up to normal operating temps, but I do not think I have ever seen above 180...is that about right (even when it is not cold)?
rico334
10-27-2004 06:49 PM
