Engine tempeture,Antifreeze mixture, how hot?
Here's what I've notice. I did a check with my refractometer to see if I'm at 50% ratio with antifree vers. water. At first check I was at 27% mixture. My 5.9 would run around 190* crusing and go over 200* on hard starts or hills. No trailer, empty. I added more antifreeze so I'm now @ 40% mixed. The motor is running slightly hotter at a cruse but seems to jump up in temp. faster under the same driving habits. It's like it's running hotter now as I get closer to the 50% mixture.
Is this normal? what is yours running at.
Seems normal to me. I often see 200 degrees cruising down the road in the summer time, and about 210 when hitting the hills while towing.
Did you add the correct type of coolant (HOAT)?
MikeyB
MikeyB
JBradley500
11-08-2010 07:48 PM
dodgediesel
09-23-2007 03:27 AM
