Engine Tap / Tick 1200 rpm's and higher
Old 12-08-2003 | 01:50 PM
psajb's Avatar
Hi all!
I'm new to owning a diesel, I just purchased the truck in October and I have about 1500 miles on it. I have a tapping noise that begins around 1200 rpm's and continues the highing you go with the rpm's and the tapping increases. The tap sound like a gasser with a valve stuff. Is this sound normal for the cummins? Forgive me if this is a stupid question but I am new to the diesel world. Thanks in advance! ;D
Old 12-08-2003 | 09:58 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Re:Engine Tap / Tick 1200 rpm's and higher
More than likely it's just the sound of the diesel compared to the gas job you used to drive.....they do make noise.
Old 12-08-2003 | 10:28 PM
DF5152's Avatar
Ive started A topic like this in the past and was gonna start one again tonight but figured i'd add tp this one. Now that it is cold out the tick noise is very prevelant it almost sound like a bad lifter or improperly adjusted valve. it very loud on start up and quiets down after a few minutes. an ideas the truck only has 4000 miles
Dan
Old 12-09-2003 | 07:36 PM
rjweiss's Avatar
Could be a mis-adjusted valve, but Cummins doesn't call for valve adjustment until 100k or so, if I remember correctly.
No harm in taking the valve cover off and trying your hand at it, if not, maybe worth a trip to the dealer (bad word) :.
Or, let it be, a slightly larger gap is better than smaller. Less clearance can cause a burnt valve.
Could even be an injector, try a fuel additive just for the heck of it, something like Stanadyne.
Ron W.
Old 12-09-2003 | 09:06 PM
Hairy1's Avatar
Mine has the same noise and my brothers '03 3500 has the same noise also......both at about 6000 mi. sounds just like you are describing. not to worry
Old 12-09-2003 | 10:19 PM
mitchkim's Avatar
could it have something to do with the winter fuel ???
maybe the centane level is low ???
could it be a exaust leak ???
Old 12-10-2003 | 02:50 AM
Vaughn MacKenzie's Avatar
Backwards Piston Syndrome
Hopefully you guys don't have this http://www.turbodieselregister.com/f...threadid=81370
Vaughn
Old 12-10-2003 | 04:43 PM
1sttruck's Avatar
Mine also made a noticeable ticking sound after several thousand miles, which was worse when cold and usually went away when warmed up. Either normal break-in or some combination of fresh Delvac 1300, Stanadyne, and a new fuel filter at 11k miles seems to have fixed it. The filter was dark gray, and was changed because it didn't seem to accelerate as well as it use to on the freeway. I still hear some light ticking when it's cold, which I'm guessing are valves, and I'll check those when I get some time.
LovinTheTorque
09-14-2013 01:02 PM
MTC
01-02-2008 08:53 PM
stirpicult
34
11-15-2007 09:50 PM
59FORD
08-10-2005 09:09 AM
haulywood
06-11-2005 12:27 AM
