Engine swap issue
Engine swap issue
Have a buddy with an 06 4x4 6 speed. Blew the engine so he went and bought an engine that came out of an 04 auto. After getting everything put back together the tranny wont engage. Loosen the bolts a half a turn on the tranny and it will engage. Should he get some type of adapter kit or something so the 04 engine will fit onto the 06 tranny.
We would appreciate any help
Thanks
Thanks
Cummins Guru
What do you mean by not engage? Did you try starting engine with trans in gear ? If you did that can you then get any gears? Possible input shaft binding on pilot bearing.
Not sure but just a thought.
Years ago when I changed a 318 Plymouth engine I had a similar problem but with an auto trans, it was the flywheel bushing. That particular year Plymouth used 6 different size bushings. Simple to change though. I would check with a Dodge parts department and see if there were any different crankshaft bushings for that application.
Just my thoughts though, nothing I'm sure of.
Don
Don
Cummins Guru
Engine with auto trans doesn't have a pilot bearing installed on crankshaft. So I hope you installed one into crankshaft. Also make sure the transfercase isn't in neutral gear?
If you have electric NV273 or manual shift NV271 they both have neutral gear selection.
dan123dbl
02-13-2015 05:47 PM
Time2play
03-24-2011 09:52 PM
SWATPARAMEDIC
10-19-2009 03:25 PM
