engine oil poll!!
Old 05-17-2005 | 08:57 PM
  #31
Boss Hoss 540's Avatar
Put the Mobil 1 Delvac in at 1000 miles---never had any problems in 6 different oil burners using it.
Dino---I used Delo in the early 80's and like it but oil has changed a lot since then.
Old 05-18-2005 | 05:36 PM
  #32
Dieseljunkie's Avatar
Ive used standard castrol dino oil the first couple changes, but I noticed Chevron Delo 400 is on sale at costco.. a case (enough for two oil changes) is 36 bucks. Can't beat that... I think I'll go get some for the next oil change which is about a week hopefully.
Scott
Old 05-18-2005 | 08:08 PM
  #33
runamuk's Avatar
I just did my second oil change with Mobil 1 (5-40) Synthetic, after enduring the Rosemella I had to say no more! Wife is pregnant and , you get the idea,Mobil 1 from here out
Old 06-01-2005 | 12:19 AM
  #34
Tony Montana's Avatar
I ran Rotella T until 25K and then switched to Amsoil 5W-40. At the same time I did the diffs and 5-speed with Redline, and the transfer case with Amsoil. I took a guess at how much fluid I'd need for the transfer case, and ended up with several spare quarts so I went ahead and drained as much as I could get out of the power steering and replaced it with synthetic. I figure if the power steering fluid gets hot enough to warrant a stock oil cooler (yeah, there's a small one located below the intercooler; at least there is in '03), synthetic fluid couldn't hurt and might help.
Old 06-01-2005 | 01:53 PM
  #35
XZILR8N's Avatar
After Delo changed its additive package to contain moly I switched from factory fill Valvoline PB (with moly) to Delo 400 15-40W CI-4 Plus. In addition, its easy to find at Wall Mart or Costco.
I chose not to spend $ on oil analysis, nor going to long drain intervals using $ynthetics on a high compression diesel. Instead, I choose to spend the $ on more frequent changes at every 5K using a top brand HD oil with Fleetguard Stratapore premium filter. That way, I know all the soot plus any contaminates (diesel fuel, etc.) are flushed and replenished with fresh oil/filter on a regular basis. Just my preference and its working very well so far.
Old 06-01-2005 | 04:12 PM
  #36
hammerjammer's Avatar
Don't make any difference what kind of oil you use as long as it is the proper rating and changed regular. I got 100,000 miles free oil and filter change when I bought my truck,so whatever comes in the DC can is what they put in it, every 6k miles.I believe the dealer said it was mobil.
Old 06-01-2005 | 05:11 PM
  #37
DR3500's Avatar
My first three oil changes were free by the dealer. after that I put Premium Blue Extreme in it, I couldn't find the oil i wanted for the next one so back to the dealer's oil and filter. Last time I put Royal Purple in everything but the tranny.
Old 06-01-2005 | 05:48 PM
  #38
trik396's Avatar
Mobil Delvac 15w40 at first change - 2100miles
Old 06-02-2005 | 10:47 PM
  #39
bauer500's Avatar
Used Rosmella at first, ditched it and went to Blue and love it..... Just my 2 cents.
Old 06-17-2005 | 10:44 AM
  #40
njmaier's Avatar
Where can I get some Mobil 1 synthetic 15-40?
Old 06-17-2005 | 12:08 PM
  #41
IA_James's Avatar
The synthetic Mobil is called "Truck and SUV" and comes in 5/40 only that I know of. Wal Mart carries it, and I see it comes in 5 qt. jugs now too. I ran it this winter because I can't plug mine in, and it gets sloooowww when it's below 0. I'm back to running Delo right now, being warmer and all.
Old 06-17-2005 | 02:22 PM
  #42
widelod's Avatar
I have always been a Castrol fan and use their <i>Tection Extra</i> (found it on sale buy 2 gallons get one free) It does produce the "oil smell' for about the first 500 miles fater a change
Old 06-17-2005 | 06:58 PM
  #43
Peterbilt's Avatar
I use 50%/50% Valvoline Premium Blue and Valvoline Premium Blue Extreme and go 6K to 7K miles. I can get Blue at Advanced Auto Parts, but can get the Extreme only at NAPA. At least in this area.
Pete
Old 06-17-2005 | 07:16 PM
  #44
Mr. Dog's Avatar
anyone using penzoil? That's what my local dealer uses. Any and all comments welcome.
Old 06-17-2005 | 09:17 PM
  #45
nickleinonen's Avatar
doesn't exist... you can get M1 15w50 but it isn't CI rated... the truck&suv 5w40 is good stuff, nearly identical to delvac1 5w40... very good engine lube oil...
i'm right now running XD-3 0w40 pao base synthetic...
Quick Reply: engine oil poll!!
