engine oil poll!!
Old 05-10-2005 | 06:52 AM
nonford's Avatar
Whatever the dealer uses. I have lifetime unlimited oil changes with them. What a deal.
I feel everytime I go for a change, that is another 80 - 100 off of the sale price. Makes me feel better that i got the truck.
Old 05-10-2005 | 12:40 PM
4x4not's Avatar
Wow, that is a good deal. That's worth several thousand dollars. My dealer gave me one free oil change
Old 05-10-2005 | 03:02 PM
Tom488's Avatar
I used to use Rotella, but like others, switched because of the stink. Mobil Delvac 1300 is in stock at my local store (right up the street - can't argue with that), and they finally got rid of the stupid foil seal, in favor of a plastic pull-up spout (like they have on the 5-gallon buckets). As an added benefit, the spout is the perfect diameter to fit inside the fill hole, and support the entire bottle.
Yep... for me, it's ALL about the packaging
Old 05-10-2005 | 03:55 PM
GBPB's Avatar
I thought I had decided on premium blue but since I can't find premium blue or delvac I have decided to try the Rotella again. It has worked for me for three trucks. It might as well work for the fourth(unless is smells like everyone says)
Thanks for all the good input!
Old 05-10-2005 | 06:34 PM
Childofthewind's Avatar
[i] I was told that it is because the crankcase breather hose hangs right on the drivers side and puts out all of that stinky rotalla vapor!! The ford I had never did this because it uses an egr. [/B]
Well it's not actually the EGR, that's a different system. It's PCV. though they both are piped into the intake somewhere.
The Cummins doesn't have either PCV or EGR, apparently the Ford has both.
Old 05-10-2005 | 08:26 PM
Roger Ramjet's Avatar
I use Rotella T, no problems so far and I cannot smell very much, due to painting for many years so odor is not a problem
Old 05-12-2005 | 03:55 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
WallyWorld SuperTech 15W40 oil and SuperTech filter. Go ahead and laugh everyone !!!! The oil is Cummins approved so what the heck!! A fair bit cheaper than the others that have been mentioned. Heard that it is bottled by Pennzoil/Quaker State anyhow. Ran my '99 for 150k+ on the stuff. No problems.
Old 05-12-2005 | 04:19 PM
bluebull's Avatar
Hey Dorkweed where were you when I asked about supertech 15-40 on a thread I started the other day? I'am planning on doing the same thing, except I prefer fleetguard oil filters. Did you tow much using supertech and does the truck burn any oil, the 99 that is? I have not completely decided due to the extreme temperatures we experience up here. I suppose I could always switch to Rottela T 5-40 for the winter months.
Old 05-12-2005 | 07:09 PM
hobbes2's Avatar
I have been using penzoil 15 w 40 long life for 20 years with no problem . we have a 6.9 ford with500,000 on penzoil and afew others on there way. Most truck and equip. shops in S. E. PA use it.
Old 05-12-2005 | 07:15 PM
Bigredmachine's Avatar
Delvac 1300 until the last change, I couldn't find 3 gallons so I used Valvoline blue. Now it smells, the next change I'm going back to Mobile
Bud
Old 05-12-2005 | 07:42 PM
Dorkweed's Avatar
Muted User
Hey Bluebull, of the 150k I put on my '99; probably close to 100k of that was with a trailer on her. I usually changed the oil at about 5,000 miles and maybe she'd be a quart low at times. Dad drives that truck now and doesn't tow at all and does mostly short trips, but the truck still runs great.
Old 05-12-2005 | 10:09 PM
bluebull's Avatar
Great to hear, I'am a cheapass but still like quality. Thanks.
Old 05-13-2005 | 05:35 PM
ZS's Avatar
ZS
I switched to Redline at 24,000 KM for everything - Engine, Diffs, Auto Trans, Xfer case...
I did the changes one at a time so I could judge any differences. cannot say I noticed any difference EXECPT when I flushed out the transmission & replaced with Redline C+ - definite MPG increase, temp drop & drive train type sounds were less.
ZS
Old 05-13-2005 | 06:44 PM
nickleinonen's Avatar
Originally posted by dieseldavesr
delvac 1300,till she,s broken in (15k) withfleet guard filter, then then mobil 1 synthetic,change every 5k miles.works for me!
changing out synthetics with just 5k miles on the lube oil??? that is way overkill i think...
right now i am using duron 5w40 synthetic and oil changes come 2x per year for me [±10,000km on the oil]
Old 05-16-2005 | 08:37 PM
hovisimo's Avatar
valvoline premium blue 15w40... cheap, has the cummins logo on the bottle, good enough for me.
Quick Reply: engine oil poll!!
