Engine died
Old 04-07-2010 | 08:01 PM
tonyG's Avatar
Engine died
I have a 2004 CTD with 65k miles and purchased 12/2003. On the way home from work today, while waiting at a traffic light, the engine idled down and died. On four attempts to restart, the engine would run for up to 3 seconds and on the fifth attempt the engine would not start at all.
Does this sound like a lift pump? I opened the filter drain and I was able to drain about 12 oz., but I could not hear the pump run as it does following a filter change. Is there a fuse or pump relay I could check? Is the transfer pump covered under warranty? What other common components could cause a similar problem?
Old 04-07-2010 | 08:16 PM
BJS Enterprises's Avatar
same symptoms when my lift pump failed except I was cruising 70mph on highway late at night with no moon. if you got the cash, this might be a good time to upgrade to an airdog or someother reputable brand of fuel pump. you should be able to get a code to come out by turning the key on/off/on/off/on and watch the odometer. I think the code is P0628. You will find many many posts dedicated to this topic. If you go with the exact replacement its a real easy fix though. I took a half day from work to do mine and it took 40 minutes to swap out.
good luck
Old 04-07-2010 | 08:19 PM
1985cucv's Avatar
sounds like a lift pump issue
Old 04-07-2010 | 08:53 PM
tonyG's Avatar
good luck
I've read the original style pump is no longer available from Dodge. Does anyone know the Cummins part number for an exact replacement?
Old 04-07-2010 | 09:27 PM
1985cucv's Avatar
you'd be better off gettting an air dog or walbro or something alone those lines not the stocker the stock ones suck
Old 04-07-2010 | 10:16 PM
tn hillbilly's Avatar
Geno's has them.
Marshall
Old 04-07-2010 | 10:23 PM
tonyG's Avatar
Is there anything in the fuel, that I could check, that could cause a pump to expire quickly? I filled up yesterday (26 gallons) from my usual source. Until it died today, there was no indication of any problem in driveability, mileage, smoothness or any other operation.
Old 04-09-2010 | 06:08 AM
tonyG's Avatar
I have code P0628 and I ordered a factory replacement pump from Geno's. The dealer said the lift pump is covered under the 5yr/100,000 mile warranty and not the Cummins 7yr/100,000 mile warranty. Is this correct? Wasn't the lift pump supplied by Cummins as part of the engine assembly?
Old 04-09-2010 | 07:56 AM
patdaly's Avatar
Depends on where it is located. Block mounted pumps ( prior to 04.5 MY ) were covered under Cummins, in tank should be Dodge.
Really doesn't matter, because any Warranty pump moves it to the tank, where it becomes a hassle to change.
Old 04-09-2010 | 05:34 PM
tonyG's Avatar
I installed the replacement pump and problem solved. I was a little concerned at first because it took twice as long to prime the system as it does following a filter change. Thanks for the help.
NickBeek
05-02-2008 08:41 PM
Rob1325
11-19-2005 06:25 PM
Tommy93w350
20
11-01-2005 11:07 PM
Mark Hodowanec
01-17-2005 09:15 PM
JerryB4
10-09-2003 10:09 PM
Quick Reply: Engine died
