engine codes
Old 05-13-2005 | 09:54 PM
Chipper24's Avatar
engine codes
today i turned my key off and on 3 times and the codes 0603 followed by 0602. anyone know what these mean? thanks in advance.
Clint
04 ctd. ez stacked with power pup. auto trans. with ats tc and valve body. ats 4"exh. boost,trans and pyro gauges. afe intake. 6" tuff country lift. 37x13.50/20 toyo's. dual fox racing shocks up front. singles in the rear. kenwood 7" touch screen dvd player. 2 JL 10w3's under back seat. JL mids in all doors.
Old 05-13-2005 | 09:57 PM
Chipper24's Avatar
engine codes
sorry the fist code was 0633 not 0603.
Old 05-13-2005 | 10:00 PM
HorseHauler's Avatar
P0602 Control Module Programming Error/NotProgrammed
P0633 SKIM Key Not Programmed in PCM
Old 05-13-2005 | 10:01 PM
Chipper24's Avatar
Talking
so what does those mean? rookie here.
Old 05-13-2005 | 10:11 PM
lol rookie here too...
the P0633 code is the security key. do you have the grey key? it has a chip in it that is supposed to be a theft device.
not sure about the other one. someone will chime in
Old 05-13-2005 | 10:24 PM
Chipper24's Avatar
yes i have the grey key. but i thought that it would have been programed from the dealer......
Old 05-13-2005 | 11:39 PM
prolly just a fluke and the dealer can jusr clear the code...
Old 05-14-2005 | 12:23 PM
RN1's Avatar
RN1
I have heard of people having both of those codes after downloading with a Power Pup?
Don't know if this helps....Robert
Old 05-14-2005 | 01:58 PM
AK RAM's Avatar
Yeah, both of those are caused by using the downloader and are typical of most downloader users. After I tried the downloader, I had to have the dealer program in a new SKIM key code to get that one to go away. Even the dealer with his DRB could not get the P0602 to go away and is still there today. Will probably be there forever. Neither will affect anything. Even the coded SKIM key feature still works fine.
Old 05-14-2005 | 06:32 PM
Chipper24's Avatar
thanks for your input guys. im just happy its nothing bad
Old 05-16-2005 | 09:02 AM
4X4 HULK's Avatar
I have the code P0633 SKIM Key Not Programmed in PCM. I do not have the gray key my key is black. I ask the dealer about this code and of course they where clueless and they could not clear it. I do not have or have I ever had a downloader. This code showed up after I had a re-flash.
Old 05-16-2005 | 11:22 AM
STATELINE's Avatar
chipper,
I have the power pup & get the 0602 some times, never effected anything. You can clear it with the pup if it makes you feel better.
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
mbenedict
07-21-2007 09:19 PM
tacohat
07-17-2006 02:27 PM
alltimelow1
04-06-2005 07:28 PM
Quick Reply: engine codes
