Engine block
the 53 blocks were a particular casting batch(so to speak) and the issue has long since been resolved. the worst thing you'll have happen to our newer blocks is freeze plugs loosening and popping out under heavy load. but not too common.
That can happen with old blocks too.
that's correct pourin, " the worst thing you'll have happen to our newer blocks is freeze plugs loosening and popping out under heavy load" didnt say it only happens on new blocks. just that those are the only discovered problems.
24Vford
01-02-2007 11:14 AM
1320
05-17-2003 03:28 PM
