Engine assembly torque specs same for 02 as 03????
Old 07-09-2008 | 07:47 PM
Checkmate's Avatar
So I bought a "factory service manual" CD for my engine assembly task. However I am assuming that even though the guy told me it was up to 2006 the manual stops at 2002 because it only lists I believe a 235 and 245 hp version.
My problem is that I followed this manual for all of my clearance specs (main bearings, rod bearings, etc) AND also used the torque specs for the main bearing caps (130),Connecting rods (73) cam bolts (18) , oil pump bolts(18) etc.
I need to know if I can continue with the assembly, or if there are differences and I will have to re torque bolts??
I'm gettin ready to put the head on and want to find out first. ALSo, seeing only 18 lbs on some of these bolts, should I be using thread lock ? The manual did NOT state to.
Help much appreciated, Thanks
Old 07-09-2008 | 07:54 PM
Rpainter's Avatar
I can not speak for the main bolts but the connecting rods on the 3rd gen trucks use fracture cap rods and the torque spec is 22 ft lbs,44 ft lbs and thena 60 degree turn on each bolt. no set torque number
Old 07-09-2008 | 07:55 PM
Checkmate's Avatar
Lovely :-(
Old 07-09-2008 | 08:06 PM
Rpainter's Avatar
https://www.dieseltruckresource.com/...ht=torque+spec about half way down the page
Old 07-09-2008 | 08:13 PM
Checkmate's Avatar
Crap, that most likely means that all my clearances need re checked !! Better now than after it's installed I guess.
Anybody have a clearance list ????
Old 07-09-2008 | 09:41 PM
Checkmate's Avatar
Anybody have the girdle specs ??
Old 07-09-2008 | 11:37 PM
PourinDiesel's Avatar
The bed plate (girdle) bolts are 43nm.
dstad
01-29-2020 11:52 AM
trik396
02-02-2013 11:39 PM
lniemeyer2
10-24-2012 12:11 PM
J Lent
60
11-03-2009 09:14 PM
jmccart
01-18-2007 03:26 PM
Quick Reply: Engine assembly torque specs same for 02 as 03????
