Electronic Wastegate
I have noticed the past month or so, that when I get into the skinny pedal, I can hear the turbo surging, then backing off in a repeated cycle...Hadn't really done it before and I was just wondering if it is the electronic wastegate just limiting the turbo. I took the intake off, checked for any debris, checked the blades on the turbo and even gave it a few spins to inspect for any rubbing and everything is good to go...
Derek
Derek
Derek
derek i wasn't trying to be a butt about your K&N! I just started noticing (read as hearing) a lot more things once I put my AEM on.
I to do notice a lot of wierd up and down boost pressure between 26 & 30 psi on my boost gauge! I have just attributed that nuance as the electronic waste gate working. ( Thank god it does I have the plastic IC)
I am sure someone wiser will chime in though! For the record I put my gauge in Xmas day and noticed the fluctuation immediately. When I installed the AEM around the fifth it just seemed to make the waste gate woking more dranatic being able to see it (boost gauge) & hear it new intake.!
Ever since I Installed the QuadZilla XZT the surging has went away from the electronic wastegate!! I was wondering the same thing a couple months back and found that this is what it was!
For boostjunkie...I really don't want to start bombing my truck just yet (i.e. modules and programmers) even though I know that they have boost fooling benefits and settings where I could stop the boost from ever going over what it should be at WOT, but is there a good reliable aftermarket wastegate that can be had? This electronic wastegate is a real hp robber. Thanks for the replies guys.
Derek
12valve
06-05-2008 12:04 PM
drewblood
04-15-2007 08:53 AM
SmokinDodge12V
34
07-13-2006 11:11 AM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
