EGT limits
Old 07-18-2005 | 09:42 AM
grandblanc's Avatar
EGT limits
What is the normal egt for these 600's and what it the upper limit you should look out for?
Old 07-18-2005 | 11:24 AM
Nuttymopar's Avatar
I just install my EGT gauge this past weekend. I have the 325/610 with an auto. I was surprised how fast it got hot.
Seemed to jump right up to 800* - 900* without even trying that hard (level ground, fair amount of throttle). But then after that, even WOT, it took a little longer to get it up around 1250* - 1300* or so. Cruising around easy on the highway (about 70 - 75) it stayed right around 600 * - 700* or so.
This is a stock motor with only a Pro-Guard 7 air filter and a smooth torque tube into the turbo. Hits about 35 lbs of boost with WOT.
My egt probe is PRE-Turbo so numbers will be higher then POST- turbo.
They say anything after 1350* is bad. NOT to stay at those temps very long as things will start to melt.
Old 07-18-2005 | 11:27 AM
DMH's Avatar
DMH
grandblanc; Is your EGT probe pre- or post-turbo?
I just got mine installed, post-turbo, on Sat. And running around on Sunday, mine was reading between 400 and 600 degrees, just running around. If I stomped on it going up a hill, it would climb to about 800 degrees, but as soon as I backed out of it, it would drop back down to about 600 degrees.
I'm no expert, nor do I play one here on the forum, but I have heard that pre-turbo, the temps can get as high as about 1300 degrees, but you don't want to run it very long that high.
I am sure that others, with more experience will chime in with more information.
DMH
Old 07-18-2005 | 11:35 AM
John Rodriguez's Avatar
Tire Hater
I've pegged my competition autometer pyro at 1,600 stock turbo going down the track at 460whp, truck still runs fine
You can push the limits as long as you realize they can push back.
Old 07-19-2005 | 08:54 AM
grandblanc's Avatar
Mine is pre-turbo. What type of boost pressures are you all getting as well?
Old 07-19-2005 | 11:14 AM
DR3500's Avatar
Mark@ TST told me that the 600's are good up to 1450 deg. I too have seen 1600+ on mine which can be allright as long as you are not there long. you don't want sustained EGT's above 1450.
Shipskym
02-05-2014 11:27 AM
drtwister
04-10-2005 08:06 AM
bigfoot
03-18-2003 06:28 PM
furious70
03-13-2003 06:26 PM
bullfrogjim
10-17-2002 10:50 PM
Quick Reply: EGT limits
