duramax cp3
Very similar except for the fittings. The Duramax has larger ports to allow suction for fuel flow, since they don't have a lift pump, at least for the LB7 and maybe the LLY engines. Not sure about the new LBZ(sp?) version.
MikeyB
MikeyB
Top's Younger Twin
Somewhere I heard that the CP3 off the 8.3 is what is being used on the Ram for a High Perf pump. Bigger lines and a different gear to make it spin faster for the high HP trucks. Anyone know about this?
Scotty
Scotty
Fred,
I dont know about the electrical connection for the dmax pump but you would need new hp fuel lines to make it fit.
I also dont know if it mounts to the gear housing in the same exact way.
Originally Posted by John Robinson
The 8.3 cummins has a total diffrent fuel system called a CAPPS system. It wouldnt work with a cp3
i think there is a hpcr version around too, or it was the isl that was hpcr???
the ISC and ISL are HPCR engines , the pumps on these engines are known as the CAPS II , they still have some pieces of the original CAPS pump to them. they are nothing like the CP3 pump
Dwitt0187
10-14-2012 09:34 PM
wap
27
09-03-2008 02:10 PM
megacabrule
33
05-10-2007 01:07 PM
