Dtc p1755
Old 08-22-2013 | 08:58 PM
Z-MAN's Avatar
Dtc p1755
I need help to find out exactly what's causing this code. Any ideas? Thanks.
Old 08-22-2013 | 09:00 PM
Z-MAN's Avatar
Sorry, I forgot, 48RE 2006 5.9L 4x4 93k miles.
Old 08-22-2013 | 09:05 PM
BigIron70's Avatar
Cummins Guru
Diagnostic flow chart maybe of some help. Most likely the throttle valve actuator, but check the wiring also for any water intrusion into the connector.
Old 08-22-2013 | 09:35 PM
Z-MAN's Avatar
Thank you Big Iron, I've changed the TTVA motor and checked the wiring but the the code is still there and the truck is running up to 2500 rpm before is shifting in the second gear. Maybe I've got a bad ttva motor again but I bought it new.
Old 08-22-2013 | 10:25 PM
BigIron70's Avatar
Cummins Guru
there are two calibration tests that I usually run after replacing the actuator. Possible those tests need to be ran to calibrate new actuator to PCM. If you think you have a bad actuator may want to try this test first.
CButler610
17
06-14-2019 09:09 AM
Z-MAN
0
06-27-2013 06:49 PM
djp9747
02-24-2005 10:30 AM
Bradleysram
02-05-2005 05:16 PM
mkubacak
11-19-2004 12:42 PM
Quick Reply: Dtc p1755
