Dropped Valve?
Old 05-23-2009 | 12:35 AM
dslpwr81's Avatar
Dropped Valve?
What is the main reason or cause for a dropped valve? Why does it seem its always number #6 too? This may be an ignorant question, but fill my little mind please. What are some ways to prevent this from happing if any? Thanks
Old 05-23-2009 | 09:37 AM
ropnjessi's Avatar
Excessive heat, mine dropped on #4
Old 05-23-2009 | 10:36 AM
NickBeek's Avatar
The valves typically don't drop per say, it is the valve seat. The seat is pressed into the head, and when it gets too hot (heavy hot rodding) it can drop down holding the valve open. The valve held open then hits the top of the piston when it comes up to TDC, causing carnage. IT can happen on any cylinder, IF there is more of them happening on the #6 it is because that cylinder does not cool as well as the rest.
Little mind filled.
Old 05-23-2009 | 11:29 AM
ropnjessi's Avatar
Here's my story from the recent past. I have a picture of the piston with the valve pieces stuck in the top if you would like to see it, no damage to the wall...
.https://www.dieseltruckresource.com/...d.php?t=227944 I
Old 05-23-2009 | 02:04 PM
ScienceOfSpeed's Avatar
i had both of my exhaust valves drop on my number #3.truck is in the shop now. hey ropnjessi, did u have ur injectors sent out and check while ur truck was down? i am thinking that maybe my injector on number#3 took a crap and that is why i dropped the valves
Old 05-23-2009 | 04:02 PM
ropnjessi's Avatar
Well I had the shop check the injectors out (not sure what there qualifications are for that), the shop seemed to think they looked good, so I went with there opinion. Its been a few months now and the truck has the power and responsiveness back, I was glad it finally broke cause I had no idea what was going on with some of the early signs....
Old 05-23-2009 | 04:05 PM
rich's Avatar
ad em drop on #4 and #6 2 different trucks
Old 05-23-2009 | 04:09 PM
i was thinking about sending my injectors to Don at Formula 1, i have bigger injectors so i want to make sure that everything is kosher before i put the truck back together.
Old 05-23-2009 | 09:43 PM
GlennRMK's Avatar
Hey Ropnjessi, did they just change the piston, rings and and cylinder head to fix or???
Old 05-24-2009 | 12:06 AM
ropnjessi's Avatar
Yes they replaced the #4 piston complete, and rebuilt the head, around $4000.00.....
Old 05-24-2009 | 12:24 AM
dslpwr81's Avatar
Little mind filled.
Ya, I fully understand what occurs when it happens and and how it happens and that the seat is pressed in the head and etc..., I just never really knew what actually causes it to happen. So the main culprit (spelling) is heat for the most part then? Thanks bud!
supersonictoys
14
12-01-2007 04:04 PM
scout98
08-05-2007 02:39 PM
Jeff K
01-15-2007 07:05 PM
Warlord
07-23-2006 10:15 PM
Swamp_Donkey
05-14-2003 09:31 AM
Quick Reply: Dropped Valve?
