drive shaft harmonic balancer
Old 08-25-2012 | 11:41 AM
joebaker82's Avatar
Does anyone know if i can take my drive shaft harmonic balancer off? I have a one piece shaft that vibrates at 70mph, the rubber holding it on is starting to dry rot. What should i do? Ive heard of putting a 08 aluminum drive shaft on but i dont know the part number. Any ideas or should i just replace the balancer?
Old 08-25-2012 | 02:39 PM
seafish's Avatar
Easiest is to call Rich at Doghouse Diesel and see if he can source you a stock one-piece aluminum for your truck. If he can't source it stock, he can cetainly make one custom.
They one piece aluminum shafts gone up ALOT in price, over $800 list, though if you can source the mopar part# that fits your truck configuration yourself, then you can often find them at mopar discount internet parts houses forabout $600.
You can look CAREFULLY at this post to determine the pasrt # that fits your particular truck--
https://www.dieseltruckresource.com/...9&postcount=91
Or, if you have a quality driveline shop in your area, they can make you a replacemnt from either steel or aluminum.
joe newton
12-10-2006 01:53 PM
apwatson50
07-13-2005 08:04 AM
krandall
06-07-2005 06:29 PM
acdc
03-13-2005 09:43 AM
TGCTD
10-18-2004 08:02 PM
Quick Reply: drive shaft harmonic balancer
