Does Winter Front Incresen MPG
Old 10-10-2006 | 05:20 PM
Mark Hodowanec's Avatar
Does the winter front increase MPG by keeping the engine warmer?
Old 10-10-2006 | 08:04 PM
merrillr4's Avatar
By no means am I a expert on this topic, but from what I know, if you do NOT use one in the colder climates it will hurt your fuel mileage. So I guess you need to ask yourself, can you afford NOT to get one?
Old 10-10-2006 | 09:09 PM
carcrz's Avatar
W/ my blade grille on in June, my mileage went down .8 mpg. I haven't tried it on in the winter yet.
Old 10-10-2006 | 10:34 PM
goose2's Avatar
Our dodge diesels get there very worst mileage before they reach opp. temp. The quicker you can get them to opp. temp. the quicker you will start to get better mpg. The one thing that you have to watch when useing the winter front cover is blocking to much air that cools the auto tranny cooler.
Old 10-10-2006 | 11:24 PM
bdo's Avatar
bdo
Can the winter front be slid in between the radiators, so the intercooler and tranny cooler are left exposed? I haven't looked, so no idea.
Old 10-11-2006 | 10:58 AM
Even if it could,it would block the air from flowing thru the radiators/Intercooler.
Old 10-11-2006 | 10:59 AM
No worries on tranny cooler - I got a NV5600.
I think I'll go the cheap way & block it w/ cardboard.
Old 10-11-2006 | 02:44 PM
goose2's Avatar
I used cardboard last year and it worked fine. It is a heck of a lot cheaper than the winter front cover.
Old 10-11-2006 | 02:50 PM
05mxdiesel's Avatar
If you used the winter front you wouldn't mind paying the 100 dollars for it, because it is pretty sweet and very simple to take off and on and adjust for airflow.
Old 10-11-2006 | 04:43 PM
DBLR's Avatar
Here if you buy it here in IA it's $125.00 + Tax, that buys a lot of fuel at $2.41 and cardboard cost nothing.
Old 10-11-2006 | 11:37 PM
coobie's Avatar
To each his own on the winterfronts verses the cardboard.I paid $100 for my dodge winterfront,the way I see it if I can afford a $40,000 dollar truck I can cough up another $100 bucks for the winterfront. coobie
Old 10-12-2006 | 12:01 AM
Lunyfringe's Avatar
Only issue I've seen with cardboard is to be sure to cut out the CENTER of the cardboard... line it up with the center of the fan... saw someone put one on that had the gap on one end...
the fan wasn't getting enough air, and would kick on all the time going down the highway..
Old 10-12-2006 | 05:42 AM
Good Sugestion - thanks.
Tedonlin150
46
11-21-2011 10:45 AM
mr T
01-31-2007 04:12 PM
big jimmy
01-16-2007 09:00 PM
Mark Hodowanec
11-14-2006 09:50 PM
Quick Reply: Does Winter Front Incresen MPG
