Does a glacier or waldboro pump remove air?
Old 02-11-2009 | 04:28 PM
sallyman1's Avatar
I want to get added filtration to my diesel truck. i know fass and airdog systems are superior but what about a home made kit for 1/3 the cost? if you were to buy a dual filter pad (that wold host a 2 micron filter and seperator) couldnt you just hook it up after a waldboro,raptor or glacier pump? would that remove air like the fass or airdog?
i looked at the diagrams but i still cant figure out how those systems remove air? all they do is dump excess fuel back to the tank.
Old 02-12-2009 | 10:01 AM
BLACK PEARL's Avatar
IMHO no system removes any air. If fluid has entrained air in it and you put the fluid under pressure the air bubble will disappear, even with as little as 5 psi. I have a GDP system and am happy with the set up. Was going to piece one together but the shipping added up and was a little up under the cost of the GDP.
Old 02-12-2009 | 04:25 PM
sallyman1's Avatar
so what u r saying is that it doesnt pay to buy parts seperately because itll add up to the price of a airdog/fass? I like the compactness of the fass and airdog. i know you can get fleetguard filters for the fass but what about the airdog?
Old 02-12-2009 | 05:20 PM
Yup unless you can find all the parts locally, Shipping adds up from 3 or 4 different places.
Old 02-12-2009 | 05:52 PM
sallyman1's Avatar
im going to check princess auto for a generic filter pad assembly. what about the water seperator thats just a filter in itslef right?
Old 02-12-2009 | 07:04 PM
If you want to run a 2 Micron filter like the GDP filter system. You can use two of these filter heads:
http://store.airflo.com/p174769.html
Run a Fleetguard FF5320 2 Micron Fuel Filter and Fleetguard FS1212 Fuel/Water Separator.
Cross Reference
2 Micron spin-on Fuel Filter:
Donaldson P551313
Luberfiner LFF3347
Baldwin BF7633
Fleetguard FF5320
Fram P8334
Fuel/Water Separator:
Donaldson P558000
Luberfiner LFF8020
Baldwin BF1212
Fleetguard FS1212
Fram PCS5062
Old 02-12-2009 | 07:48 PM
trik396's Avatar
You can fab up a system using a Walbro, a bypass regulator, CAT filters/heads for less than a FASS and it'll be better, imo.
I did it. Others have as well.
Old 02-13-2009 | 08:54 AM
sallyman1's Avatar
where did u get the bypass regulator?
Old 02-14-2009 | 01:08 PM
GDP was set at around 15psi some run up to 40psi.
Here's a choice: http://www.generant.com/
Old 02-14-2009 | 01:35 PM
chrigu's Avatar
you can change the spring an washers on the regulator from the pump kit
i run with 25 psi, with no problems.
Old 02-14-2009 | 01:47 PM
RowJ's Avatar
Originally Posted by BLACK PEARL
IMHO no system removes any air.....
Might not say that if you saw the FASS demonstration display with clear plastic fuel lines on it. It's inpressive.
Originally Posted by Black Pearl
...If fluid has entrained air in it and you put the fluid under pressure the air bubble will disappear...
That's probably why FASS puts the air/water separator before the pump.... on the suction side.
RJ
Old 02-14-2009 | 06:02 PM
Originally Posted by RowJ
That's probably why FASS puts the air separator before the pump.... on the suction side.
RJ
Not according to their web site.
I would love to see a demo of it, where is that possible.
Old 02-14-2009 | 06:22 PM
sallyman1's Avatar
lol. put clear lines on the glacier and walbro and see if theres air
Old 02-14-2009 | 06:26 PM
Raspy's Avatar
If you're getting air on the suction side of the lift pump you are either out of fuel, have a hole or crack in the suction line, or are sloshing the low fuel level enough to pick up air with the fuel.
The Glacier system bypasses a large percentage of the fuel right back to the tank and, in the process, takes any air in the system with it. So, if you run out of fuel or change the filter, the air gets sent to the tank with the excesss fuel and separates there.
Old 02-14-2009 | 06:39 PM
sallyman1's Avatar
exactly raspy exactly. reason i cant make sense of why fass and airdog systems cost $500-1200 dollars US? is there magic marbles in them? im going to buy 2 filter pads from princess auto, lines and a pump for about $183.00
Quick Reply: Does a glacier or waldboro pump remove air?
