Dodge Allison conversion kit
Old 05-28-2007, 09:04 AM
Hooligan6's Avatar
Has anyone installed the Dodge Allison conversion kit on a 2500 yet.I saw the kit on DE STROKED website what are your thoughts on this kit? Is another after market tranny better than the Allison?
Old 05-28-2007, 09:19 AM
jrussell's Avatar
They all are! A built 48RE will handle way more power than a stock Allison. The extra gears in the Allison would be nice, but not worth all the trouble/expense IMO. If you're set on swapping in an Ally then give Suncoast a call, they also offer it for Dodge's.
If you're looking to stay with a 48RE then Goerend, HTS, ATS, & DTT are the big dogs who can bulid it strong for you.
Old 05-28-2007, 09:49 AM
Hooligan6's Avatar
Thanks I wasn't sure which direction to go on this. I've always heard allison was good.I'll look those other guys up what's your top pick from those guys you listed?
Old 05-28-2007, 10:44 AM
jrussell's Avatar
My top choice is Dave Goerend and that's who I went with. The others are all just as good from what I hear. I think it's safe to say you can't go wrong with any of the ones mentioned.
Old 05-28-2007, 10:56 AM
jwb600's Avatar
I would put a correctly built 48re up againist a built allison anyday. the allison is not what everyone builds it up to be. it also has more parts to be upgraded, so that means more parts to break. thats my .02
Old 05-28-2007, 02:29 PM
FourX4Fabber's Avatar
Not sure Suncoast is going to continue with that swap, you would have to check with them. I plan on just going full billet in the 48re then let the turbo sing
Old 05-28-2007, 09:57 PM
PG4x4's Avatar
Just one thing I noticed today while look at an allison tore down, and having a broken 48re output shaft in my hand. Look at the difference between the output shaft on a 48re and the allison. Size does matter.
Old 05-29-2007, 09:06 PM
Muted User
Jfaulkner's Avatar
The output shaft on a 2wd Allison is huge compared to the 4wd version.
Old 05-30-2007, 04:15 AM
Dodgezilla's Avatar
Just wait till you can get a 68RE if you want the extra gears........
Old 05-30-2007, 05:06 AM
annabelle's Avatar
Built 48RE is the way to go. Allison is over hyped.
Old 05-30-2007, 10:03 AM
DTR 1st Sergeant
soulezoo's Avatar
Anybody hear anything yet on 68RFE or the Aisin for how they are working or if there is going to be an ability to retro-fit?
Suncoast has put up the "coming soon" post on their website.
Old 05-30-2007, 10:09 AM
jrussell's Avatar
I'm not sure how motivated Suncoast is on that project. I've heard not very.
It would be sweet to have the extra gears. When they can put a built one behind a 5.9 with 700+ HP and it holds doing 20psi 4x4 launches, I'll think about it.
Old 05-30-2007, 10:17 AM
DTR 1st Sergeant
soulezoo's Avatar
I just talked with suncoast, they are just about ready to offer the Allison conversion. It will be "built" and it will use stock x-fer case on 4x4. It will also be, and I quote, over $10K!!!
Old 05-30-2007, 10:19 AM
jrussell's Avatar
Guess I can see how they got motivated to get going on it again. Over $10k...LOL!
Old 05-30-2007, 10:21 AM
DTR 1st Sergeant
soulezoo's Avatar
Also, when speaking to them, they said that 68rfe was NOT (emphasis theirs ) going to be a good candidate for the retrofit, the Aisin probably would be but they are not pusuing either at this time.
Quick Reply: Dodge Allison conversion kit
