Do I need injectors???
Old 06-27-2013 | 11:30 AM
Dagselander's Avatar
I'm trying to figure out if I need new injectors. I've read numerous threads on this forum, but this is my first post. It started out that my truck would not start below 40 degrees in the winter, so I would just keep it plugged in and it started like a champ every time. This went on for the past 3 yrs. but all of a sudden this summer it is having a real hard time starting after sitting a couple hours. once it starts it runs like a million bucks. Also, If I get it started, drive it around, turn it off and then start it again it starts right up. Any insight would be greatly appreciated before I go blow 3K on injectors... Thanks
P.S. truck has 250,000 miles on it
Old 06-27-2013 | 12:49 PM
pdogg's Avatar
you can have them rebuilt for much less than that...
Old 06-27-2013 | 03:25 PM
soulezoo's Avatar
DTR 1st Sergeant
While this may/may not be your issue, the ECM has to see 3000 psi on fuel pressure at the injector before it will signal to fire. Old tired injectors (that you undoubtedly have) will have a lot of "leak back" and have trouble getting that pressure at start and there you go.
With that many miles-- have them checked out, it is probably replacement time.
Old 06-27-2013 | 04:32 PM
Thanks for the info. Any idea where to get re-manned injectors at a good price? Also, is this a job that I should attempt? I do most of my own auto work but I have never done injectors on a diesel.
Old 06-27-2013 | 11:42 PM
Cummins610's Avatar
The job is straight forward if you have wrenched before. Look here for instructions, just ignore the parts about switching tips http://www.glacierdieselpower.com/im...ip_install.pdf
I would call Exergy Performance for new injectors, will give you a good price as any and you will receive quality Bosch parts.
http://www.exergyperformance.com/contact.html
With that many miles I would set the valves and replace the FCA too.
Do you know if your lift pump is working? Being a 03 it will be block mounted unless converted to a intank pump, with the engine not running bump the starter, you should hear a pump running by the drivers side engine or fuel tank.
Old 06-28-2013 | 10:26 AM
Thanks cummins610. That helps a lot. I checked it out and yes the lift pump is working. What is the FCA?
Old 06-28-2013 | 11:00 AM
Cummins610's Avatar
It is on the cp3 injection pump, controls pressure to the fuel rail, with time they may get lazy and cause a ruff/Lopey idle and poor performance.
KRB
05-20-2007 06:20 PM
GSP
12-11-2005 12:20 PM
W.F.O.
11-03-2005 10:33 AM
darrenG
06-21-2005 10:24 PM
BIGOKIE
07-21-2004 05:53 PM
Quick Reply: Do I need injectors???
