diff oil mixing and fill level tolerance
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
Are there any conceivable problems mixing 75W-90 with 75W-140 (both Mobile 1 syn)?
Also, after filling the diff oil to the fill line (marked on the diff), it ended up being about 3.4Q. That fill line is a good 3/4 in. below the fill hole. I know most posts I've read here talk about filling up to the hole itself. Does anybody know the tolerance for fluid in the diff? It seems like I saw it printed in the DR service manual but I can't find it now. Something like +- 1/4 in. or maybe +- 1/2 in.
Thanks!
Thanks!
Seems I put in 4 qts when I used the stock rear diff cover. THat brought it right up to the Full ine printed on the cover. I now have a PML and it takes 5 qts to get it to the same level...I would think if you put in a full 4 you should be OK..
Totallyrad
08-03-2009 10:34 AM
redpoint5
36
02-08-2007 05:07 AM
Bad Ramer Jamer
12-25-2005 11:13 PM
