Diesel smell in cab and blowing fuel under truck
Diesel smell comming into cab with an apparent leak under truck. Noticed vapor and drip coming out of tube hanging down behind fuel filter (2003 5.9). Oil level looks good, not trans fluid? Is there a high psi pop off valve or something there. Going to start tearing into it now to keep the young ones safe from fumes...It's the family daily driver.
Fleetguard Introduces Enviroguard Open Crankcase Ventilation System for Class 5-8 Vehicles. Enviroguard(TM) systems provide superior aerosol filtering of crankcase emissions, commonly known as blowby. According to John Clevenger, Fleetguard's Director of Product Management, "Blowby is the condition that occurs when high pressure gases and oils escape around piston rings. The oily mist attracts dust and airborne particles, resulting in an accumulation on the engine and on the surface beneath it. This condition increases the clean-up required in the engine compartment. It also results in unsightly oil drips on highways, parking lots, garage floors and driveways. Enviroguard(TM) eliminates this messy oil drip problem for good."
This is the problem... 3 Big chain parts stores do not carry it nor can they get it sooo it's off to the dealer at just a little over $100. This seems a bit much but it is what it is.
Ridiculous
07-16-2006 06:08 PM
Scotty
88
01-01-2004 08:00 PM
cmckinney
16
10-09-2003 04:46 PM
