Diesel fuel on everything
When I came out of work today there was a big spot under my truck. So I took a look underneath WOW what a mess. There is diesel fuel dripping off everything. I started it up and didn't see anything so I don't know where it's all coming from. I stopped at the dealer and they gave me a loaner until they can get it fixed. I hate driving that little Neon.
I had a similar experiance. I went to change the oil and found everything wet. At 1st I thought I had an oil leak but after looking at it more carefully, it ended up being the power steering pump. Now i have to take that in and pay to have it fixed due to my mileage. I wish it was cover under the powertrain warrenty.
Did you try to drain the water out of the fuel/water separator? If so, that could be it. It drips down on top of your front diff. And, make sure you close it off completely or you'll have a mess. Good luck.
I haven't drained the water seperator for months so it's not that but I still checked it. It might be the power steering fluid, I did notice that the arm out of the steering gear box was as far forward that was wet, and EVERYTHING behind that was dripping. I just assumed diesel because it had a green tint. My sense of smell doesn't work so wasn't sure. I know the coolant isn't green and the trany isn't green. What color is the power steering fluid?
mr T
10-04-2004 09:06 PM
