diesel fuel in engine oil
We have a 04 ho with 30 000km at the shop and the "drivers" complained of fuel filling the crankcase....about 4 liters over in 2 - 300km. I happened to notice the filterminder missing and opened the air cleaner box to find that the filter was sucked half way into the tube and it was plugged with enough dirt to plant potatoes. We changed oil and filter , but it overfilled the crankcase again . It runs fine , but i think they're going to have to pay for some rings.....I don't know what else would cause this ?
But it's running smooth....no long crank time. Have not checked for excessive blow-by yet. I hope its an injector.....we don't have time for an engine overhaul.
I did a search (should have done first) and i found on the forum that there is a problem with some injectors leaking inside the valve cover...will pull off tomorrow....if we have time.
I cant see any injectors leaking , I even phoned the tech line and the say that i should see fuel spraying from the bad injector. I put lots of dye in the fuel , cranked up the rail pressure and still no luck.
using dye can be a tough one to find sometimes , just better to remove all six injectors and replace the o-rings and most likely you will find one is cut or eroded thru and allowing the return side fuel to leak back into the engine. remember the pump could also be leaking fuel back into the gear area also. you wont find that with a blacklight.
The engine has no miss and sounds normal, so it shouldnt be "dribbling fuel down inside the cylinder" . I am going to get the inj pump pulled off to hopefully see something leaking there. If there was a bad o-ring I would think we should see diesel pouring up from the o-ring area.
It is the injection pump; there is a weep hole and its out of there full throttle.......kind of that they would design weep hole that leaks into the crank case..........kaboooom!
dodge_guy
06-25-2015 05:42 PM
ClassA4x4
05-16-2013 11:49 AM
realoldandcrust
02-14-2008 09:53 AM
big red psd cc
11-21-2005 05:09 PM
