Diesel consumption @ idle
Old 05-06-2007, 12:55 PM
Raspy's Avatar
Location: Smith Valley, NV (sometimes Redwood City, CA)
Originally Posted by bulabula
After a hurricane a few years ago, I idled my engine for about 8 hours while hooked up to a 2KW inverter that was used to power fans and wet-vacs to help clean out the water from a marina store.
After refilling the truck and dividing by 8 hours I figured it burned under .5 gallons per hour.
That as a good real world test.
I used to be able to run my Perkins diesel powered 42 foot Ketch at about 1/2 gallon an hour if I took it easy in smooth water. My buddy put many miles on his boat at 1/3 gallon an hour. It seems like while idleing a Cummins with no load, 1/4 to 1/3 gallon an hour would be about right. In your case you had a demand of about 2-3 hp. So .5 makes a lot of sense. I can't see how the number could be at 1 gallon, as previously said, unless it was a gasser.
Wetspirit
Old 05-06-2007, 02:43 PM
coolslice's Avatar
Originally Posted by DiEseLjunKy
Look at what that UPS driver is saying. It wouldn't burn and cook if it was left there for an hour or more after shutoff. I disagree on the "expenisve oils" comment cause a good bypass filter and oil analysis with extended drain intervals will work out a lot cheaper than dinos every time. Now these guys running bypass' with syns and going crazy with the 3,000 mile oil changes yeah thats a waste.
That's true on the extended change intervals to an extent, but I would guess these trucks at UPS and FedEx only get an oil change around every 20,000 miles anyways. That's using the cheapest oil they can find, if it runs low in between oil changes, they just dump a couple of quarts in and it's good to go. They could care less about oil samples and the like, all they care about is if it HAS oil.
Old 05-06-2007, 05:19 PM
bulabula's Avatar
Originally Posted by annabelle
Was that with the high idle enabled or not?
annabelle, sort of (for the most part) - I used a high idle "wooden stick" between the throttle pedal and seat to try and keep the revs above 1000. I don't have the cruise control high idle set up if thats what you're referring to.
I know I said under .5, but I found my notes later and it was really ~.3 gal/hour.
FWIW, I used to work at UPS in the late 70's putting myself through college and I remember the day when management said to shut off the engines for each stop - a few guys rolled there eyes and said that for whatever money they were saving on gas - they'd end up spending it on new starters. But that never happened as I recall. We used the Ford I-6 back then in the 6 and 8 cubes.
Old 05-06-2007, 06:10 PM
annabelle's Avatar
Thanks.....
Relic
01-19-2012 03:20 PM
wcbcruzer
09-30-2008 11:54 PM
bailman
01-13-2006 08:39 AM
sullivad
24
02-14-2003 07:41 PM
ICEBOX
02-09-2003 06:08 AM
Quick Reply: Diesel consumption @ idle
