Did I get the right pressure solenoid?
I ordered from Transmission Parts USA for a 48RE but the package I just got says D22958 46, 47RE 1996-UP on it. Is it the right one. I hate dropping the pan only to find out I have the wrong part. The transducer says 48RE on it.
This is what I ordered
http://www.transmissionpartsusa.com/...-000053396.htm
u r fine, it just doesnt come printed on the bag for some strange reason...i ordered the same exact part from the same exact website lol. i imagine ur replacing the pressure solenoid and the transducer correct? well i just did mine and wow wat a difference. works like new now
Im not seeing a transducer on their site anywhere, I 'm probably in the wrong area through.
I need to order these two parts as well.
p0wd3rp1l0t- Does your tranny just seem to shift better now?
From what i've heard it just takes simple hand tools to unbolt everything. I believe they are on the side of the valve body. I haven't seen it first hand so don't quote me on anything.
Need 7/16" socket and T-25 Torx head.
Drain fluid and remove filter for a while before R+R, unless you have a lift. If not you get drips everywhere.... mouth, clothes, eyes.
Other than that.... easy DIY job!
RJ
I'm thinking about replacing mine...
Is it best to use this kit http://www.electricaladvantage.net/a...erkit00up.aspx or, just replace those 2 parts ?? ( transducer & solenoid)
The top one is from PATC here:
http://www.transmissioncenter.net/dodge.htm
DTT recommends these GM Solenoid Conversion units. Claim they have had zero problems with them, after over a yr in use.
Just bgt one after my 5th factory solenoid started to hang up before shifting.
Another thread on the subject HERE. if interested?
RJ
RJ
Got a picture of it?
Got it from my installer, supposedly at his cost.
It looks identical to your top pic from http://www.transmissioncenter.org/.
Will take a snap shot and post it asap!
RJ
RJ
