did i get the right flash??
Old 12-03-2005 | 12:11 PM
INsIdious's Avatar
The dealer flashed my PCM a while back, and now anytime the weather turns cold it sounds like my engine is coming apart all through the rpm range. It is very predictable. above 70F, everything sounds okay, below 70 and it sounds worse than a 2nd gen. The PCM label update says it was a P56040478AE update. The closet number i could find at dodgeram.org updates was P56040478AG which shows to be for a 6.9 liter engine?? How can i find out if i got the correct flash??
Old 12-03-2005 | 12:57 PM
J BODY's Avatar
You would have to run that number on the MDS at the dealer under the tech tools tab. That would then tell you if it were up to date, or if there were updates avail. I would say from your explanation that you are worrying about nothing.
Old 12-03-2005 | 04:48 PM
cschulz's Avatar
The last two digits of that number show the revision of the flash code. The latest revision for 18-037-04 that I know which I just had done is AI. Hope this helps.
Old 12-03-2005 | 06:12 PM
Hounddog's Avatar
No way to install a INCORRECT flash.
cramel
22
10-23-2008 08:06 PM
Flattman
10-16-2007 01:07 PM
CamperAndy
05-18-2007 12:36 AM
8mpg
04-28-2006 10:08 AM
04RAM2500
13
12-17-2004 10:02 PM
Quick Reply: did i get the right flash??
