Dealer B.S.
Old 11-08-2006 | 09:46 AM
Dan Marino's Avatar
Originally Posted by RustyJC
Same thing on a friend's 03 3500 dually. IIRC, it took months before they finally changed out the fuel pump and cured the problem.
Rusty
Was it under warranty?
Isnt it weird that I can ask you guys and you know what is under, and the service guy doesnt
Old 11-08-2006 | 09:48 AM
RustyJC's Avatar
Yep, it was warranted, but it happened within the first year or two that he owned the truck.
Rusty
Old 11-08-2006 | 10:47 AM
realsquash's Avatar
It's either the lift pump or the FCA on the CP3... You used to have to replace the whole CP3 if the FCA was pooped but I think you can get just the FCA now.
Andy
Old 11-08-2006 | 11:43 AM
79warlock's Avatar
The FCA is available now and can be tested by unplugging the connector to it while idling, the engine should get noticeably louder(rattle more). Plug it back in and it should return to normal. If it doesn't return to normal, the FCA is most likely going bad.
Old 11-08-2006 | 01:39 PM
Dan Marino's Avatar
I searched FCA for 10 minutes couldnt find what it stood for. (found FCA lots but no description) Forgive my ignorance-what is it.
Old 11-08-2006 | 02:56 PM
lmills's Avatar
Fuel Control Actuator
Old 11-08-2006 | 06:24 PM
PARTSGOD's Avatar
As for the mopar filter price
it is $21.25 msrp
Old 11-08-2006 | 08:46 PM
XLR8R's Avatar
Dan - you for sure need to find another dealer's door to darken!
Did you try unplugging the FCA connector?
Old 11-09-2006 | 07:14 AM
Dan Marino's Avatar
Not yet. I havent picked it up yet. hopefully today. I will certainly try this FCA connector.
lmillis - Thanks for telling me what it was.
Old 11-09-2006 | 01:36 PM
GrandpasRam's Avatar
The way they found mine was after all the other stuff got worked and Chrysler Star was out of ideas, I noticed a fuel pressure drop jsut BEFORE the stumble in RPM occured, and told the service manager the FCA could be sticking. He called Star, and they said pour a pint of 2 cycle marine oil into the fuel and see if it stops sticking. It did stop for that tank full of fule, but as soon as I filled up again it started stumbling again, so they changed the CP3 and no more problem with that. Hope you can test yours and get it fixed under warranty. I think the injection pump is covered under the 100K warranty.
Old 11-09-2006 | 01:52 PM
Dan Marino's Avatar
Thanks, it sounds so simple. It really chaps me that when I asked to see if they could check it out for me they acted crazy - like it was going to cost me BIG TIME and they really didnt have time to look for it - like I was bothering them or something.
Old 11-09-2006 | 06:18 PM
Hounddog's Avatar
Screw the advisor.Print this thread and give to dealer owner.Your truck will probably get looked at and fixed without much issue.
fflarry
08-25-2007 10:39 AM
RHC
03-25-2003 06:03 PM
03-25-2003 05:39 AM
wheels
13
10-18-2002 04:59 PM
gerryz
10-18-2002 07:28 AM
Quick Reply: Dealer B.S.
