In Cylinder EGR???
Old 03-22-2010 | 10:28 AM
  #91
AH64ID's Avatar
Originally Posted by StealthDiesel
It's the 3rd injection event.
Even installing an aftermarket cam (which has absolutely no EGR effect or overlap built into it) in an 04.5 engine will not cure the instant black engine oil on these engines.
Correct, the in-cylinder effect is created thru cam, injection timing, and 3rd injection event. A programmer like the Smarty series will bump the timing, and the cam will improve the flow of air, not really a way to remove the 3rd event, but one can hope.
Also I am going to be ordering a cam this month, and will be going with a Colt Stage 2 Cam.
Old 07-26-2012 | 08:43 PM
  #92
AH64ID's Avatar
Originally Posted by AH64ID
Just got off the phone with Cummins/Holset
HE351CW
Compressor Wheel
Inducer: 60mm
Exducer: 82mm
Turbine Wheel
Inducer: 68mm
Exducer: 60mm
Turbine Housing 9cm2
So 60/60/9 is correct.
They are going to call me back with the pressure ratio.
I know this is an OLD, or OLDER, thread but I wanted to update some info. It turns out I didn't get 100% of the info from Holset. Not sure where the disconnect was, and they never did call me back with the PR.
But the info below is more accurate.
HE351CW
Compressor Wheel
Inducer: 60mm
Exducer: 86mm
Turbine Wheel
Inducer: 65mm
Exducer: 58mm
HE351VE
Compressor Wheel
Inducer: 60mm
Exducer: 86mm
Turbine Wheel
Inducer: 70mm
Exducer: 60mm
Both versions of the HE351 are rated at approx 61-65 lb/min.
Old 07-27-2012 | 10:01 AM
  #93
Hintonc393's Avatar
Hey Gang,
I have not had much time in the past months to post or let's alone say read the forums. Too much stuff all at the same time in the pipeline. Sorry 'bout that. As you can see, even though I'm silent, we're not sitting on our hands.
A few things that I would like to point out about the UDC.
I think the most important news with the UDC is that you not only get a tool but you get also professional help in using the tool to get the tuning right.
AKA, the (stock) parameters that you modify with the tuning software are NOT written into a stock software!
Your modifications are written into my " base software"!
WTH the base SW is? That's the software I use in all my tuning. In other words, the tweaked / performance oriented stock software which is the base for all Smarty tunes. All limiting factors like for example the boost / torque /
limiters ( simple stupid examples there are hundreds of parameters tweaked in the base software ) are already taken care of. You don't have to fiddle with them. I already did the legwork for ya. Example, when the 6.7L first came out, it took me over 2K dyno runs to optimize that "base SW". That's been well worth my time tho The result is that the power can now be taken anywhere by tweaking in the Duration / RP / Timing.
This is where your modifications land in Smarty....
Since it's time to open up my smallish box where I keep my lil secrets in...
I have turned off the late injection event in all my softwares since late 2005 /
early 2006. The late injection event is OFF by default in all my softwares since then. 'Nough said? OK, gotta admit, in a couple SW releases I had forgotten to turn it off. I guess nobody really noticed it.
Oh yeah, I've heard that fantasy a lot of times...turning off the late one gains a fantazillion in mileage. Now you know the (real world) answer to that.
Hint, when you read " Load " , think it as Throttle Position and everything will become ( much ) easier to tune 'n understand.
Cheers,
Marco
The third injection event has been gone for some time now.
Old 07-27-2012 | 10:03 AM
  #94
AH64ID's Avatar
Correct, this thread is about 3 years old. I was just correcting some turbo info.
Old 07-27-2012 | 10:06 AM
  #95
Hintonc393's Avatar
Thanks for coming back and setting the turbo info right. Most of the miss information on here is from things like that, old info that was not right and no one ever making it correct.
Old 02-14-2013 | 09:26 PM
  #96
levigarrett76's Avatar
Good good info
Old 02-20-2013 | 04:28 PM
  #97
AH64ID's Avatar
Originally Posted by levigarrett76
Good good info
Where have you been hiding?
Old 02-23-2013 | 06:25 PM
  #98
Been busy, drove truck for few years, married and divorced, now I'm traveling working out of town back in my cummins again. Driving my freightliner I was a little more concerned with the inner workings of 12.7 Detroit . How's yours been doing?
Old 02-25-2013 | 09:28 AM
  #99
AH64ID's Avatar
Things have been good, super busy with work and such, but life/truck are good.
Old 07-10-2013 | 03:35 AM
  #100
I mostly hang out on cumminsforum. My 2007 is sold, sad day but she's just been sitting in shop. Maybe had 3000 put on in last year. Gonna replace it with a cheap 12 valve Dually that don't bother me sitting
Old 07-10-2013 | 09:23 AM
  #101
AH64ID's Avatar
That sucks!
I only put about 8-10K miles a year on mine, but it's a good time when I do.
I spend much less time on the forums these days, and this one the least.
motrapper
16
01-22-2014 07:57 AM
MOJO1
08-04-2009 06:28 PM
cgmorgan06
11-15-2007 04:02 PM
Journier
11-22-2004 02:56 PM
Quick Reply: In Cylinder EGR???
