Cruise control keeps disengaging
Old 05-07-2013 | 12:16 AM
GregC's Avatar
04 3500, just had the engine rebuilt and now the cruise doesn't work right. I'll be calling the shop tomorrow. I paid way too much to have to put up with this. I can set the cruise and it kicks off within 30 seconds or so, can't get it to set again until you cycle the key again. any ideas?
Old 05-07-2013 | 12:27 AM
Spooler's Avatar
Vaccum pump lines are chaffed and are leaking. Vaccum pump is behind the passenger battery. Trace the black poly line to under the cowl panel where the vaccum tank is and over to the underneath side of the drivers side battery where the dash pot is.
Old 05-08-2013 | 11:46 AM
GregC's Avatar
I've been using the search button on this one and am pretty sure you're right. I guess I'll work on that after I replace a rear caliper and pads. Passenger side is hanging up a little bit. man, I wish I had a garage!
Old 05-08-2013 | 06:00 PM
whiskers's Avatar
Yep, those vacuum lines crack very easy. They may look intact, sometimes they are broken in half and still look good ! Run every inch.
woodrep
01-20-2010 10:43 PM
jmccart
07-17-2008 10:05 AM
Pooter
05-31-2007 05:08 PM
Steelheader1
12-04-2006 12:30 AM
akeithbrown
07-24-2004 02:28 PM
Quick Reply: Cruise control keeps disengaging
