which cooler line is return
Old 08-11-2007 | 08:20 AM
vc's Avatar
vc
can some please post which trany cooler line is the return line - i want to disconnect it and put it in a bucket when i change out my tranny fluid so i can do a full change out. any pics would be greatly appreciated.
thanks in advance,
vc
Old 08-11-2007 | 08:46 AM
jrussell's Avatar
Kind of hard to explain, but the "hot" line goes from the tranny to the heat exchanger/cooler mounted on the engine. The return line should go from the tranny cooler by the radiator straight back to the trans. That would be the line you want. Hope that makes some kind of sense.
Old 08-11-2007 | 09:43 AM
vc's Avatar
vc
ok - i'll look and see if i can spot the one from cooler to tranny - i appreciate the help.
vc
Old 08-11-2007 | 10:06 AM
jrussell's Avatar
Here's a clear pic of the "hot" line (the line you don't want). It has a temp sensor installed in this pic.
http://www.dieselmanor.com/diy/CMS3-gauge/G3image6.htm
The return line that you want is paired with that "hot" line. You can't see it very well in the pic, but basically it's the other line (there's only 2 of them there).
Old 08-11-2007 | 11:25 AM
no_6_oh_no's Avatar
Rear line on transmission is the cooler return line.
Old 08-11-2007 | 12:08 PM
vc's Avatar
vc
thank you folks - i appreciate it.
vc
Scotts_D250
07-10-2011 01:05 AM
isb07
11-18-2009 05:12 PM
ctd4stan
05-18-2009 02:56 PM
RHC
11-22-2007 08:52 AM
ckennedy
06-23-2006 08:21 PM
Quick Reply: which cooler line is return
