Coolant System Flush
Hello everyone,
When performing a "home-made" coolant flush, how do I drain the coolant reservoir? I used Super-Tech (Wal-mart brand) coolant. Is that ok? I comapred ingredients with Prestone and they are exactly the same.
Thanks,
Jamie
Thanks,
Jamie
Not sure if yours is the same but , mine is in 3 notches , lift a little then push out if notch-sideways to get out , then just dump .
Ethelinecycale , [ my computor makes me spell bad ]
Zerex G-05 HOAT type. You can use they Mopar or even....Ford gold coolant. They are all the HOAT type. If you like the standard green, I suppose just use it and flush and fill more often.
Originally Posted by Jmac
Hello everyone,
Thanks,
Jamie
Thanks,
Jamie
Originally Posted by kully560
what is hoat antifreeze I thought zerex go-5 was diesel antifreeze
hi coobie what is so special about the hoat, do yo know ,also how is your revo tires holdind up I need tires in spring do you have pros and cons yet
HOAT is the type of coolant. Hybrid Organic Acid Technology
http://www.valvoline.com/pages/produ...asp?product=10
It is an extended drain interval coolant.
tndiesel
05-02-2012 11:05 AM
afoulk
09-21-2007 06:23 PM
