Coolant dripping from bell housing inspection cover?
Old 01-03-2009, 07:51 PM
BroncoAZ's Avatar
I've had my 06 for about 7 months now, After it got down into the low 30's for a couple of nights I noticed a small puddle of coolant under the truck. I noticed today that the puddle is getting bigger. Upon inspection I found that the coolant is coming out of the inspection cover for the bell housing. I looked around and couldn't find an exterior leak. Are there freeze plugs or something that might be causing the leak? The truck is well under warranty with 24K on the clock, so if I can't figure it out it will be making a trip to the dealer for warranty repair. The motor is all stock.
Thanks
Old 01-03-2009, 07:57 PM
KenCatskin's Avatar
Look for a short (4"?) hose under the turbo almost up against the block and attached to two hard lines with hose clamps - tighten the clamps.
Seems to be a common problem.
Old 01-04-2009, 12:03 AM
FastTaco's Avatar
What he said. I had to double clamp mine after it started again 2 years later.
Old 01-04-2009, 12:06 AM
BroncoAZ's Avatar
Thanks, anybody got a pic of where it is? I saw a silver corregated looking line coming down from the turbo to the oilpan, probably an oil return line.
Old 01-04-2009, 11:28 AM
FastTaco's Avatar
Its a rubber hose with like silver heat wrap and has 2 hose clamps on it. Passenger side close to firewall.
Old 01-04-2009, 10:11 PM
BroncoAZ's Avatar
I found the leak, exactly as described. I repositioned and tightened the clamp, we'll see if it fixed the problem. Thanks.
Old 01-06-2009, 10:20 PM
dieselfumes57's Avatar
mine is leaking now too
Old 01-07-2009, 09:27 AM
Neight's Avatar
Mine started leaking there a few weeks ago. Of course I thought the worse when I saw the leak but when I crawled under there it was nice to see that its minor.
Old 01-07-2009, 10:37 AM
PCM
PCM's Avatar
Saw the same on mine. I tightened the clamps before towing the fiver 300 miles. Checked it when I returned home and it was dry. I'll keep a check, but so far, seems to be the simple fix. PCM
Old 01-07-2009, 10:39 AM
Mlucas's Avatar
i think the dealers change the clamps out to a different kind-could be wrong. I had them do it to mine after it started leaking...
Old 01-07-2009, 06:36 PM
marksblaster's Avatar
Yep, Mine did the same thing last winter. I had the dealer put a new hose and clamps on, Just had to tighten them last week because it started leaking again! Mark
Old 01-07-2009, 06:53 PM
NickBeek's Avatar
There is a new hose with a smaller inside diameter as well as what should have been on there from the beginning some spring clamps available at your dealer. I went and picked mine up before Christmas. I haven't had a chance to put it on yet, but I will soon.
Old 01-09-2009, 06:49 AM
stressedout's Avatar
Ya'll just made my day. Mine has been leaking and i assumed the worst. I thought it was a freeze plug on the back of the engine. I will take care of this tonight.
Old 01-16-2009, 04:15 PM
Crankpot's Avatar
Yep, took mine to the dealer for the same leak. It was the line below the turbo. Fixed for free. 14000 on the clock.
Old 01-17-2009, 07:14 PM
Tobin's Avatar
Just noticed mine leaking today also. Tightened the clamps and hoping that will take care of it.
Tobin
Quick Reply: Coolant dripping from bell housing inspection cover?
