console brake light blinking
i would look at the E-brake. At the top of it there is a sensor that has to come into contact with the E-brake when its released. If its not touching just bend it a lil bit so it does. It flashes when you put in gear? So check for play on the Ebrake setup under dash. Also easy way to check it. With truck off and on flat ground/wheels chocked. Put in gear and it should flash. Pull up on the foot pedal and see if it goes off.
Joey-D
12-12-2011 12:52 PM
