Confused about what fuel pumps i actually have in my truck
ive done alot of lurking around (both before i signed up and after ) reading and am confused on which fuel pumps are on my rig..
i have a 04.5 ram 3500 4x4 diesel ..
has the plaque on the engine that says 325hp.
from my build sheet :
built on April 27th 2004
Engine: ETH-5.9L HO Cummins Turbo Diesel
it was bought Brand new..
which Fuel pump/lift pump do i have and where do i find them at?
i know where the fuel filter is.
thanks for your time.
not in the tank unless the dealer fix has been installed under warranty work. his lift pump(04.5) is the little black canister that is mounted vertically to the back of the fuel filter.
The 04.5 and 05 trucks are virtually identical, except that 05's have the fuel pump in tank from the factory. 04.5 trucks still had it on the fuel filter housing.
Also the early 05's had the plastic intercoolers until DC finally realized that was a big mistake. Then later 05's went back to metal intercoolers.
know that i know the setup.
how do i go about figuring out why lately its been hard starting.. sometimes (only 2 times) 6 cranks to start..lately its been 4-6.. use to be 2 MAX..
fuel filter has been changed .. no mods to the fuel system.
i run Drews Brew in it.
46K on the clock.
im looking at the GDP Walbro Kit but if my stock fuel lift pump or CP3 is going id rather get it replaced in warranty before i modify and install the GDP kit.
46K on the clock.
cwoodall
10-02-2007 12:25 PM
oldblues
04-06-2007 03:36 PM
Intercooler
06-04-2005 07:48 PM
chuckhallett
03-14-2005 01:26 PM
