Compression Test Numbers
Old 03-12-2008 | 02:22 PM
Racing41's Avatar
Does anybody know what are some good numbers for a compression test? I hear 400 and 350. If there are any Cummins techs on here, would you please let me know? Its a 03 with the HO and it has 138K on it. Thanks for your help.
Old 03-12-2008 | 02:37 PM
dozer12216's Avatar
The compression figure is some what elusive. If could measure would be nearer 400 on good engine. Believe the procedure for compression is loading on a dyno and measuring the CFM of blowby.. Another test haven't seen lately is a comparative starter current draw for each cylinder, while cranking with injection disabled.
Old 03-12-2008 | 03:25 PM
John Faughn's Avatar
It might be best to say why you are looking for that info ?
There is a lot more to it than just one number , like how many cycles during test , what the pressure is on the 1 full cycle , all with a warmed up engine .
But generally about 400 lbs , all cylinders within 10% of each other , I forget what the min. pressure before repair .
Old 03-12-2008 | 10:48 PM
Redline Ram's Avatar
the min. is 350 psi. cylinder pressure should be within 20% from cylinder to cylinder.
cadash
12-26-2012 12:44 PM
Contractor
01-20-2011 02:30 PM
kyle_truck_pull
11-04-2009 11:06 AM
Dr. Evil
10-08-2004 11:33 AM
Quick Reply: Compression Test Numbers
