cold mornings
cold mornings
i live in wyoming and the mornings can be pretty cold.
so when its anything 20 degrees to -35 i cycle the plugs twice. the truck always starts with no problem. when it starts it runs instant at a grand rpm. my exhuast is fairly loud. so while it is reving up loud about every 30 seconds it sounds like it misses or cuts out for a split second.
warmer mornings my truck runs normal then revs up to a grand.
my dads 03 never revs up right it start. his always runs normal then in later warm up time it revs up to a grand for like 10 seconds then back to normal..
so my question is why is two 03 trucks running differnt. is mine missing or what is it doing.
my truck has 60,000 miles. never had a problem with it other then a lift pump. i do have little mods but currently it has been return to stock. the truck runs great. no lack of power. i pull a circle j horse trailer that is double walled and put 5 horses in it and no problem pulling at all. the truck has never been pushed to its limits with chips. got a superchip only casue it was given to me for free and i never use the thing. i keep it for checking codes.
My 06 model does the same thing... If you have the defrost on, it could be the a/c compressor cycling. Remember, a/c compressor is running when the defrost is selected.
It could also be the grid heater cycling..
If its the grid heater cycling, sit in the truck and watch the voltmeter while listening to the exhaust. If the exhaust stumble happens when you see the needle moving then its the grid heater.
The reason two different trucks may act differently may very well have to do with different versions of programming loaded into the two trucks. One may have a more aggressive cold mode strategy than the other.
If your dad plugs in, in some temps it will prevent the truck from going into high idle when it would have otherwise.
Sounds perfectly normal. If you have an exhaust brake, turn it on, and it will warm up much faster.
When I worked at CAT it was common to have many different software versions in the ECM for the same model and year. Manufacturers make a lot of changes on the fly.
I would not be too concerned about it. Actually, I think yours is the better version going straight to 1000. Mine does that too.
like everyone has been saying i think it depends on the program. mine right at start on a really super cold morning goes to 1000 rpm at instant start.. warmer mornings it runs at idle then to 1000 rpm for awhile and then back down......the days i plug it in it never revs up just stays at idle
snowbank
02-07-2008 01:53 PM
Rednecktastic
35
11-12-2007 06:12 AM
VikingDiesel
18
10-24-2006 11:55 AM
