Codes that don't seem to have anything to do with each other
Old 12-21-2010, 02:17 PM
genesis's Avatar
My buddy just called about his 2004 CTD.
He said he was driving down the highway and for no apparent reason it puked a bunch of white smoke and check engine light came on.
He pulled the codes and wound up with these.
They don't seem to have anything to do with each other.
Could it be as simple as a loose/bad/corroded connector?
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0237 Turbocharger Boost Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0633 SKIM Key Not Programmed in PCM
Old 12-21-2010, 02:49 PM
AH64ID's Avatar
Is he running any programmers or modules?
Old 12-21-2010, 03:37 PM
genesis's Avatar
I guess I should have said that.
Not now or ever has this truck had a programmer or chip.
it is a bone stock 4X4 crew cab.
Old 12-21-2010, 03:41 PM
AH64ID's Avatar
I would start with looking for loose connections on the crank sensor.
Reset the codes and see if they come back.
Old 12-21-2010, 04:40 PM
genesis's Avatar
10-4
Thanks!
Old 12-21-2010, 06:04 PM
Administrator/Jarhead
madhat's Avatar
I would also check the batteries.
Old 12-21-2010, 09:44 PM
TedT's Avatar
On vehicles in general, bad grounds can cause realty strange, seemingly unrelated problems.
Old 12-21-2010, 10:17 PM
sr4440's Avatar
might want to take a look at this thread.
https://www.dieseltruckresource.com/...=rubbing+wires
Joe
Old 12-21-2010, 10:56 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Verify the speed indicator ring is properly positioned relative to the locating pin in the front face of the crankshaft. Visually inspect the condition of the tone wheel, ESS, and EPS for damage.
Check the mechanical alignment of the camshaft gear to the crankshaft gear. I have seen the crankshaft gear slip on the crankshaft and shear off the locating pin.
NJTman
08-13-2015 11:49 PM
Dean Snow
05-29-2008 01:02 AM
Crimedog
10-17-2005 04:23 PM
Lil Mule
12-06-2003 10:07 AM
Quick Reply: Codes that don't seem to have anything to do with each other
