Code PO304 Cylinder 4 misfire?
Old 03-28-2010 | 11:13 PM
RAM6SPD's Avatar
Question Code PO304 Cylinder 4 misfire?
Hey everybody, my '06 2500 engine light came, then went out.? I ran a scan at home and came up with this code: Code PO304 Cylinder 4 misfire. Sometimes the truck runs rough like it is missing? So my question, "where do I begin..." Any help would be greatly appreciated. Thanks...
Old 03-29-2010 | 05:42 AM
tesla440's Avatar
is your oil level rising? Tough to start?
By what you discribed it sounds like it could be an injector issue. You should still be under warranty. Have the dealership take a look at it.
Old 03-29-2010 | 10:24 AM
Silverstreak's Avatar
#4 injector line loose/weeping, injector line BRACKET loose, injector line cracked?
Old 03-29-2010 | 12:07 PM
RAM6SPD's Avatar
Cool Code PO304 Cylinder 4 misfire?
Thanks for the reply. You know it never seems to burn oil. The oil level never seems to change, it is above the add mark right now? I change the oil every 5k. It's due right now and I'll look into that. I have 116k on the truck now and the factory warrenty ran out at 100k or 5 years for the injectors. I'll have the dealer run a dianogstics,(compression, injectors) for a 100 bucks and see what they come up with. I'll post what they come up with later in the week. Thanks again for your suggestions..
Old 03-29-2010 | 01:24 PM
OCMerrill's Avatar
If it's above the add mark and you used 3 gals at change then one of your injectors is leaking (bleeding down pressure) while it's sitting. Running past the piston and into the oil.
There are other things to check but for the most part what you said is a tell tail sign.
Old 04-01-2010 | 03:31 PM
RAM6SPD's Avatar
Smile Now what?
Thank you OCMerrill. There appears to be fuel in the oil. So now shall I replace 1 or all 6 injectors. DIY or have dealer install. What other kinds of injectors are on the market. I guess I'm asking for your advice. Thank you.
ironbrew
08-12-2015 08:23 PM
sooty
03-05-2014 08:40 AM
Valv
01-20-2012 10:48 PM
mattyfz450
03-18-2009 10:30 AM
tomm
07-26-2007 10:49 AM
Quick Reply: Code PO304 Cylinder 4 misfire?
