code P0602
code P0602
Hello
Iam new to this site lots of good information I could use some help.I own a stock 2003 dodge cummins 103,000 miles its been a great truck. But recently started having a starting problem. Changed filter the first time and it started right up. it was fine for a couple weeks. started doing it again put another new filter in it started fine. Iam on my fifth filter found if I pull the filter put it back in it will crank over afew times and start. I took it 2 a reputable shop. Not the dealership they were cetain it was the pump they replaced it and same thing they couldnt get it to start and called me. I told them to remove the filter put it back in and it would crank abit but would start. its showing code p062 they said they couldnt be certain but they felt it was the computer and they cost about $2000 but because they couldnt be certain they didnt recommend it. Anybody else out there had a similiar problem I would really appreciate any information any of you have. Thanks Jeff
cquestad
11-22-2006 11:14 AM
