code p0483 = fan clutch?
3 days ago I disconnected battery terminals to clean posts. Later on I checked for codes(didnt check before) It came up with p0483 - cooling fan speed. Fan seems to turn ok . Not running higher temps. Clutch feels ok, no slop. Is my clutch going out? Anyone else have this problem, if so how much is a fan clutch?
I have 75 k miles on it.
If it is your fan clutch you will find out when it gets warmer. Your A/C won't stay cool when you idle for a while. I never had a problem with the engine getting hot but the A/C will let you know. Mine is doing it right now. It will get fixed next month along with a few other things.
i had that p0483 along with a p0107... dealer fixed both at one shot... new fan clutch and new intake air temp sensor/barometric pressure sensor... i didn't notice anything with the p0483 but the p0107 made the engine stumble right at 1900-2000 under load and then the engine defueled big time [and set an SES code]
hey guys this is white ghost' wife he is sitting broke down on the side of the road what was to be a pay load however he has 3 codes I need help with p2509,p0217,p0483 are they all connected or does this sound like a wiring harness problem?
i had both fan related codes and i plled the fuse and it looked ok and when i put it back the codes went away,maybe a weird conection,also check where the fan conects just below the rad,it can get coroded there.
cquestad
0
02-28-2006 12:49 PM
