Code meanings on 03
Old 04-04-2009 | 10:32 PM
Black 03 2500 C's Avatar
Smile Code meanings on 03
Guys if you could help me I would greatly appriciate it.
On a recent trip from AZ to PA, pulling an empty 1,600 Car trailer the following codes appeared. P0192 "Fuel Rail Pressure Sensor Low" and P0237 "Turbo Boost Pressure Sensor Low". Could someone explain what these codes mean?
The first time the codes appeared was after climbing the steep grade on I17 from Phoenix to Flagstaff. The second time was in the hills of TN. In both cases the truck "Hickup" ran rough for a few second then ran normal. The engine light then stayed on for hundreds of miles before going out.
Thanks,
Black 03
Old 04-05-2009 | 12:00 AM
madhat's Avatar
Administrator/Jarhead
Do you have gauges? Aftermarket fuel pump? You were probably draining the rail a little. The CEL will stay on for a while after something like that sets a hard code.
Let's talk about fuel pressure first. If you don't have gauges, I suggest you get them, at least a fuel pressure gauge.
Old 04-05-2009 | 08:29 AM
rich's Avatar
yea due to the fact the 03 lift pump will go out and when it does its usaully not close to home and the truck wont run or run very well without it
Old 04-06-2009 | 12:06 PM
Thanks Guys!!
Madhat - I have Boost & Exhaust gauges hooked up, but not fuel pressure. Have the gauge but haven't hooked it up yet. That will be my next priority.
What pressure is good? If I wanted to play it safe, and just replace the original pump, any suggestions?
Thanks,
Black 03
Old 04-06-2009 | 12:31 PM
pdogg's Avatar
Originally Posted by Black 03 2500 C
... pulling an empty 1,600 Car trailer ...
man, that's a lot of cars ....
mattmanj2001
20
12-02-2010 08:24 AM
mikelobaugh
01-11-2009 09:05 PM
08raptor
10-15-2008 02:54 AM
CTD NUT
04-05-2005 04:45 PM
fitzer
03-07-2004 07:09 AM
Quick Reply: Code meanings on 03
