Clutch slip
Old 10-27-2006 | 05:13 PM
  #31
ZacHolley's Avatar
also when you kill your truck the fan should stop withing a second or less. if it free wheels for a few seconds after you kill it then its bad.
Old 10-27-2006 | 08:09 PM
  #32
isbeinside's Avatar
the p0336 code for the CKP sensor usually comes on when the engine is running rough or i have heard of boxes and programers setting it the fan speed p-code is a rationality code, and the map sensor code was also probly set by your BDDL. i would clear the codes and run with it, if one of the codes comes back repeatly, let me know i will e-mail you the testing flow chart.
Old 10-27-2006 | 09:09 PM
  #33
XLR8R's Avatar
The RokkTech sensor is an aftermarket part that advances your timing by 2 degrees max - helps with fuel economy and low-midrange torque, since the common rails are designed to be "retarded" from the factory for emissions considerations.
txsmokindiesel
05-19-2009 08:03 AM
Kman9090
06-13-2005 08:48 AM
dkinzer
05-23-2005 08:57 PM
Rocco
03-24-2005 06:02 PM
BADodge2003
08-24-2003 07:22 PM
Quick Reply: Clutch slip
