clutch problem/nv5600
Old 06-30-2012 | 11:23 PM
narleycharlie's Avatar
Cool clutch problem/nv5600
On my 05 2500,I m running out of floorboard under the clutch pedal. When the pedal is released,it starts to grab about a quarter of an inch from the floor.And it has been getting hard to get into gear.I slid under it today to look to see if it was adjustable.It s not.I don t have any hydraulic leaks.The fluid is not low.The clutch is not slipping. I don t get it .Any help would be great,dont know how much time it has left before it leaves me .
Old 07-01-2012 | 12:33 PM
vzarich's Avatar
It sounds to me like it might be time to pull that trans and take a look at what you have going on inside the bell housing. It sounds to me like you have no time left.
Old 07-01-2012 | 02:06 PM
I know what you mean,I read in another post that the pilot bearing needs to be installed by a machine shop,why so ?
Old 07-01-2012 | 03:55 PM
Adaminak's Avatar
That's only the upgraded pilot bearing sold by Valair and Southbend, and it's considerably larger than the stock size. A good upgrade if you're replacing the flywheel, but not absolutely necessary.
It's possible your hydros are bad. Not leaking, but the lines could be swelling, and therefor not moving the lever far enough to allow a clean take-up near the middle of the engagement range.
Old 07-02-2012 | 04:25 PM
papaduck's Avatar
Try pumping the clutch and see if it gets better. If it does then the hydrolics need replacing. If not you need to check the throwout bearing. It could be worn and if it is dragging it could be wearing the fingers on the pressure plate.
Old 07-04-2012 | 06:10 PM
Thanks for the replys,will check deeper into the hydro's
Old 07-30-2012 | 07:35 PM
Itsmejoe231's Avatar
When I searched I came up with this thread.
My 04 is doing the exact same thing here. There is not any noise coming from the trow out bearing and I just replaced my clutch slave/master cylinder about 3 months ago.
What did you figure out?
Old 07-30-2012 | 11:15 PM
Jim O's Avatar
My clutch felt like it was not releasing and it happened suddenly. After removing the clutch I found that the pilot brg. had piled up. After 272000kms or 170,000 miles (mostly Towing ) I decided to replace the clutch assembly. The parts store where I bought the clutch told me that the pilot brg fails often on Dodges and Fords before the clutch is worn out. The disk on the new clutch was only 23 thousands of an inch thicker that the worn one. The clutch assembly came with a new release brg and pilot brg. but I chose to use a oilite bronze bushing for a pilot brg. instead of the one that was supplied The bushing is 1" long and the brg was only about .6" long. I know I am not the first guy to do that.
Jim O
Old 07-31-2012 | 08:31 AM
I noticed mine doing this when it is hot. In the morning it does just fine. I am going on the assumption that the heat has something to do with the hydraulic lines swelling from heat and not letting the clutch disengage as it should. it got so bad i would have to turn my engine off and put it in the gear I needed and then start it back up. I noticed yesterday when slowing down for a stop sign, I would down shift till it was in 1st gear and while waiting on traffic with my foot off the brake the truck would creep forward.
Old 07-31-2012 | 09:27 AM
justin allan's Avatar
take the slave cylinder off and see how much travel is in the clutch fork. pull it twards the out side then push all the way forward and mesure the travel. should be like 5/8 travel.
Mine was doing the same thing but from new I had about 1" of travel.
If you have the upgraded hydraulics you can take off the little backer plate that is on the slave it is about a quarter of an inch that will help slightly.
Old 07-31-2012 | 07:29 PM
Haven t torn mine apart yet,no leaks.pumping up the pedal does nothing.The heat is too bad to work in.Still about the same, hasn t gotten worse.
Old 08-17-2012 | 08:58 AM
texastuff's Avatar
check and make sure your master cylinder hasn't came loose in the firewall.
dodgezilla04
13
12-04-2006 10:13 AM
TXTad
29
06-15-2006 12:11 PM
bhuffstutter
0
10-17-2005 09:41 PM
fishin fever
11-29-2003 11:29 AM
gandrews
10-24-2003 07:40 PM
Quick Reply: clutch problem/nv5600
