Clogged cat?
Old 04-03-2010 | 12:50 PM
wmonroe's Avatar
Clogged cat?
Has anyone had trouble with their cat getting clogged. I've noticed my egt's have been higher than normal and they don't drop as quickly at idle as they used to. I was thinking the extra soot from the smarty has clogged the cat.
Any thoughts?
Old 04-03-2010 | 05:01 PM
NickBeek's Avatar
Is it way down on power, fuel economy off? I have never read of a cat getting clogged on one of these trucks. I have been running a Smarty Jr for about 29K miles on the 100hp setting and mine is not clogged.
Old 04-04-2010 | 01:43 PM
Lost Lake's Avatar
I've had the Smarty jr for about 70,000 miles, but every now and again I clean the cat out.
There's a lever you need to push to clean it out, hold the lever for about 10 seconds and then let up on it. You can check it again after a few seconds and the soot dissipates. You'll see that the next time you operate the lever there is MUCH less soot, and the cat is nearly clean. Do this once a month or so.
wcbcruzer
08-18-2006 09:02 AM
G-NOTE
09-01-2005 07:36 PM
EKUgrad
05-15-2005 07:08 AM
CaughtinmyGrill
04-18-2005 06:46 PM
mhuppertz
09-22-2004 10:07 PM
