Clicking Clutch Pedal
Re:Clicking Clutch Pedal
No clicks on mine but just today I noticed a very slight squeek whenever I push the clutch pedal in. Almost sounds like a dry rubber squeek.
From: Eagle, Idaho. Please set your watch back 20 years when entering.
Mine has 700 miles on it and no clicks, but it does squeak . I suspect it is where the pedal return spring is attached.<br><br>100 Proof
Mine will do it every once in a while. I have determined that if you apply slight side-pressure while depressing the clutch (sounds tricky, but it's just a matter twisting your foot ), the click does not happen. I have not investigated, but I too am guessing it's just the return spring?
When I first got mine it did not do it but after awhile I started hearing it.I took the rubber pad off the clutch pedal and put a film of grease on the inside of the pad and put it back on and have not heard it since.
rockwind
12-17-2009 06:45 PM
Johnny_Utah
07-15-2009 10:50 PM
600 Megawatts
03-26-2008 08:09 PM
WACTD
07-25-2006 12:41 PM
