CLICK noise when I turn right, NOT LEFT??
Old 08-29-2007 | 01:20 AM
VikingDiesel's Avatar
I've talked to some other people about this and they seem to hear the CLICK as well. I obviouly cant hear it at low higher speeds, but if im stopped and I turn the wheel to the right, there's a CLICk noise coming from somewhere which I cant find where its coming from, if I turn left then NO noise, only right and pretty much almost full turn, anyone?
Old 08-29-2007 | 02:12 AM
TexasCTD's Avatar
Have you checked your track bar bushing? Mine pops a little at slow speed turns.
Old 08-29-2007 | 06:29 AM
JohnnyH's Avatar
I'd check the axle U Joints. That is a symptom of a bad one.
Old 08-29-2007 | 09:04 AM
nope, just replaced those last week
Old 08-29-2007 | 11:52 AM
chariotdriver's Avatar
Does the noise stop if you step on the brakes? It's happened to me and it was a worn bushing on the caliper (I think it's a bushing; it's the rubber part which the caliper bolt slides in).
Old 08-30-2007 | 10:40 AM
JohnnyH's Avatar
Maybe this is a long shot, but since you just had everything apart check the rotor dust shield. Maybe it got bent and is hitting something.
Old 09-10-2007 | 12:09 AM
ok, well I think I finally figured what it can be. Inner tie rod, pitman arm or the last thing which I strongly think it is that I dont want it to be is the steering gear box for some reason, inside the box itself is where the click seems like it coming from. Is there a common problem with the gear box?
marksmith
08-17-2007 02:57 AM
Sleigher
03-23-2007 12:23 PM
cheapskate
19
12-27-2006 08:05 PM
PaulDaisy
12-02-2006 12:36 PM
bnold
04-25-2006 06:57 PM
Quick Reply: CLICK noise when I turn right, NOT LEFT??
